Setup to print a model with roughly 200mm in diameter and the purge tower was set at the back half on the plate and half outside! Tried to move the model closer to a corner to no avail. Ended up not using it. Anyone seen this before? I’m on the latest version of Bambu Studio.
Yes. I had to manually move the tower. You can select it just like any other model on the build plate.
Not sure what the issue is but when I went to print a multi-color articulated dragon this AM it did exactly what you are talking about. Took me a little finagling to get both the model and the tower into a spot that would allow printing without issues.
Hope this helps.
Thanks for your reply. Interesting, printing another thing yesterday (smaller) I was able to indeed move the tower without problem.
Hi, How did you select the purg tower to move it in Bambu lab? for me it wont show it in the Prepare tab and in the preview it wont let me select it.
It usually shows in the prepare tab for me, make sure its enabled though:
