Hey all, so when you cancel a print midway it’s usually because something has failed right? Usually with the first layer going down. If you can see you haven’t got a clean first layer you generally stop the print…
So my issue with this is when you stop it the bed only lowers a few centimetres. Please can we update this so it will lower a lot further giving better area to work in to clean the bed and the nozzle.
I understand you can do this manually, the issue then is it will make you Home the extruder/bed first which can cause other issues.
