Quando il filamento si esaurisce con x1c
Hi, However with ams if you put the same setting for example generic pla and same color both in the first slot and in the second slot when the filament runs out the printer does not stop but switches to the other slot…
Instead if you use the single filament without ams the print should stop and allow you to change filament…
I have this memory lapse, help me understand
I thought it did do that.
Yes it works I solved it stops yesterday I had doubts
