Question about BS & Cura buildplate support
I’ve printed the Oreo boxes using Cura on other printers many of times without any issues.
I thought I would print one on the A1 Mini, but I noticed Bambu Studio buildplate support is printing on the outside around the model also. I assume I’m missing a setting somewhere, looking for help keeping the support only on the inside without having to paint it on every time I use it.
Thanks.
Bambu Studio:
Cura:
Try Inner brim or No-brim:
No Brim was already on, tried Inner Brim…nothing has changed…both do the same.
seems this is related to support not to bed adhesion, have you turned off supports?
I want support. I’m trying to get it to stop printing outside of the model.
Tree supports will work, but I want to use Buildplate support.
Hi @lion7718 change your support settings to NORMAL - SNUG and that should keep the support ONLY within the width of the model!
yes, that worked.
But I also found out if I uncheck Buildplate only, it works also. I think that’s a bug.
