I can confirm the “Print Again” button will allow you to print the next plate when you use “Print All”.
Here was my work flow.
- Use “Print All” to send a multi plate print.
- This starts the first plate.
- Once this print finishes, clear the bed, select “Print Again”.
- This brings up the print selection box with a picture of the item on the first plate.
- This is the key point, next to the image of the first plate, there is a side arrow button, press that and it will show and image of the next plate. Start the print as you normally would.
