Question about Start G Code
Some of my PETG filament ooze more than others. And sometimes it ruins the first layer.
With the start g-code, it prints two purge lines. After purge line 1, the nozzle moves to the middle of purge line 1 and make a pause - it ooze. Then he moves to purge line 2 and leaves strings over the whole print bed.
How and where can I change the start g code, that this “pause” is not on purge line 1? he should do that at the start of line 2 and I would like to do a second nozzle wipe before line 2 starts printing.
https://www.printables.com/de/model/322000-bambu-lab-modified-start-and-end-gcode/files
There might be what you are looking for in this link. Throughtheframe has done a lot and keeps it up to date.
I saw that already and its not that what i’m looking for. I dont know why the printer moves to the middle of purge line 1 and make that pause…
I dont find the location in the Gcode :confused:
I found this one also
https://www.printables.com/model/427261-fully-commented-bambu-lab-start-gcode-feat-chatgpt/files
I removed the whole gcode for lidar (which I done use) and it works now :slight_smile:
But there is on thing. Does anyone know which “M106 PX” the chamber fan is?
M106 P3 = Chamber fan
M106 P2 = Aux fan
M106 P1 = Nozzle fan
You can also edit the chamber fan speed in the filament setting start g code but most likely you know this already.
M106 P3 S127 @ 50%
What you are calling the purge line is called the noozle load line in the P1P start code.
Noozle?
Most typos I can gloss over but that one is funny.
That is why I copied it from the actual P1P gcode.
Hahahahah this is a very good idea :stuck_out_tongue_closed_eyes:
I have been have the same issue with the start purge line. What did you change in the G code to turn off the Lidar?
Here is my gcode
If you search for " mch " in the code, you will find my changes
Thanks. I’m still new to editing gcode. Which one do I change to stop the Lidar scan on the start purge line?
Dont check “Flow Calibration” when you send the print job :wink:
I did a flow calibration on Orca and set my flow to 1.01 on mine so I don’t check the flow calibration anymore.
You know how on the start purge line it pause to does a lidar scan and oozes. I was wondering what did you change to turn off the lidar on the start purge line to stop the oozing?
