Questions about PAHT-CF filament just received
Is the PAHT-CF filament compatible with the nozzle that shipped with my X1C received earlier this year? That information wasn’t included in the listing for the filament at the BL store, so I expected it to arrive with details. Is general information available for BL store filament and nozzle compatibility?
Hey,
PAHT-CF is compatible with the X1C directly from the start as you’ll need a hardened nozzle which is included by default. They state this on the page for the filament, which nozzle and size they recommend.
There’s also a handy page to look up which materials require which nozzle and are compatible with the AMS. Since I cannot post links for now (just signed up, only read the forums as guest until now) look for “Filament Guide” in the wiki or copy this: [https]://wiki[dot]bambulab com/en/general/filament-guide-material-table
Remove the square brackets and replace [dot] with an actual dot to get your link
If you received (as I did) the hardened nozzle installed, it is compatible.
Nevertheless, BL recommends using the 0.6mm nozzle instead of the 0.4mm to avoid clogs.
