Raft interface ironing feature
Add an optional raft interface ironing feature.
When selected, this feature would apply an ironing step on the topmost raft interface layer, before laying out the first supported (clean) layer. This, could potentially significantly improve the quality of the supported surface, since the fondation of the raft interface would be somewhat smooth (TBD).
This feature could be added first as an expiremental one. Would probably make sense if this feature is enabled/present only when there are more than one interface layer configured, and/or when the raft interface material is different (special) than the model’s. Although, ironing between the layers of the same type of material might in some cases improve the support separation as well.
Have you had a chance to test this idea, and if so how did you enable an ironing option for just the raft?
This is just a proposal for a feature.
How do we submit an actual request for the developers to add such a feature? Is this forum the correct method, or is there a separate “feature request” form, or … ?
Submit your idea as a new Issue-Feature on Github:
The developers do not pay much attention to this forum, they do respond to some ideas on Github.
As per your suggestion, a feature request was added on github.
https://github.com/bambulab/BambuStudio/issues/4354
Thank you.
