Raft settings for smooth interface layer
question on settings for raft.
i make small snowmen parts - eyes, collars, etc. If i use a RAFT (see image of RAFT, with eyes on it), the interface layer of the raft is coarse, not fine, and the eyes printed on top get a smushed first layer.
if i IGNORE raft, and make a square that is 0.32 mm high, add the eyes, or collar, on top, merge it, and raise the collar by 0.32 (i am at 0.16 layers), and first layer is PLA, 2nd layer is PETG, 3rd layer starts object, with PLA, the adhesion is great, the first layer of the collar is smooth, much better print.
WHAT SETTINGS on the RAFT can help me achieve this, so that the raft is 0.32 (or even 0.48) high, 2 or 3 layers, with a SMOOTH filled-in top layer of the raft, and no spacing between the raft and the start of the object? I’ve been experimenting, but am confused with the raft settings. The RAFT SHOULD let me accomplish the same thing as my interface block, but if i use the RAFT, the object starts at layer 4 or 5 (not layer 3), and the first layer of object is irregular, and the surface layer of RAFT is irregular.
IMAGES, the greyscale with circle is the collar, printed on MY SUPPORT BLOCK
the color image wit gold/black buttons, are the eyes on a RAFT
any help appreciated.
layers
The setting you’re looking for is Brim, not raft, I think. A raft adds an entire layer (or more of non-print related material, usually geometrically, like a rectangle) and is more similar to support. A brim is adding that thin layer concentrically around your model and is actually adhered to the edge of your model to help prevent warping. less secure than a raft, but gives you better surface finish. all3dp has a good article that bambulab won’t let me link
thanks for reply. but, i do want the raft. i want a full layer below the object, because when layer 1 is printed, it gets smushed. when i have a raft of 3 layers, and the object starts on layer 4, then layer 4 should not be smushed. but, with bambu, it is not able to make a smooth raft. SO, i created a 3-layer full object to merge with my object, my object then gets raised up to start at layer 4, the first part of object prints at 1 thru 3, and i print that in PETG, and the main object in PLA. it works well that way, and is easily separable.
again, thanks
Have you tried just printing the showman eyes directly onto a smooth pei plate instead of the textured plate in your image? I’ve had good luck with tiny objects printed in PLA on a smooth PEI build plate, and the bottom surfaces come out looking pretty darn good (even when I’m wearing my glasses haha!).
i could try that (may try it this fall). but i just love the textured pei plate, easy release, etc, and i believe it still might be an issue with the first layer being elephantized, and this affects its fit in the eye socket, etc.
and the smooth vs textured would not affect the raft structure not being smooth. and using petg as first 2 or 3 layers, then switching to PLA and the actual object, is good, because the PETG rectanglt that i create helps hold the eyes together, on a mat, until i need them :slight_smile:
I also use Raft when printing very small very fine prints for bed adhesion. I prefer a raft over using glue.
I know this is an older question, but I was able to find “interface pattern” and “Top interface spacing” in the “Advanced” menu for the support tab. Using the “concentric” pattern with “0mm” spacing I did 2 layers of raft and it was firm but not stiff. Out of 4 pieces I only had to clean up one, maybe try 3 or 4 layers to get a firm base. I am just printing basic pla.
does those raft settings give you a smooth raft, no holes in it, or grid pattern?
raft revisited - i used the concentric, and zero, today, and it worked very well. much smoother than what i got before, with other settings. it still has slightly irregular surface but not indented, not too much different than the textured bed. i will keep experimenting, maybe i’ll change from 0.2 layer to 0.16, and see what happens. if that helps, then that solves my “small parts” items, because for larger items, my results today work well
