Raft vs no raft, first layer not as smooth
doing a thin object. when doing with no raft, it sometimes does not stick to the plate. so i added raft, 2 layers, no clearance. but lookint at the slicing, the first layer of the object, when having raft (it is layer 3 when having raft), has less fill than when there is NO raft (and it is layer 1).
for raft, i have zero clearance between support and object. i’d expect the FIRST layer that contacts the raft to be LAYER ONE of object, and should be solid. I even changed surface layers bottom to be 5 instead of 3,but still no change. any feedback appreciated, thanks
601
I haven’t had much success with Bambu Studio (BS) and raft, they always tend to weld themselves to the model.
Try a brim instead.
In an ideal world models require a decent amount of surface to build-plate ratio to stick.
Depending on what you are printing, using tree support could assist. Without any pictures, that one is a guess.
You can also slow down the print for the first few layers and if you are using PLA, I have found turning off the fan for the first few layers helps things stick.
thnks. but brim not as beneficial.
the raft settings i use have first layer as PLA, then the support layer (layer 2) is PETG) and then 3rd layer (first layer of object) becomes PLA again.
and, that combination works well, raft easily removed from the objects.
and for small parts, this does work (I was making my own 2-layer object to insert under the main object, and changing filament automatically, before revisiting the RAFT settngs). but the raft settings, with zero clearance, are doing OK right now.
ok,RED arrow - part that had final surface printed at about layer 297
BLUE/GREEN arrow - a part that has that surface on the build plate - actually on the RAFT, so this was layer 3, but actually layer 1 of the object. it should have had a flat surface, like the red-arrow part.
this matches the concerns i had above, with the actual bambu slicer impression of how it would get printed.
HOW to get the layer 3 (first layer of object) to print solid, like layer 297 final layer?
Possible solution . I adjusted the INTERNAL SOLID INFILL to smaller amount (0.3 mm). THAT IMPROVED the slicer view of the object. I am printing a test as i type, to see if that makes a difference in the appearance of the first layer of object (layer 3 on print).
OK, actual print, it did improve. see surface, finer that the other orange print above. so the solid infill does help.
ISSUES (not sure if solvable). since this first layer of object is resting on other filament, it does not get as polished as when it would print directly on the print bed, so i’m not sure if it can be gotten better than this. and i don’t think there is a way to IRON a specific layer (first layer of object print) to make it smoother. so this may be a trade-off of adhesion and ease of print, versus appearance. BUT, at least i believe these settings help to optmize the actual output
and hopefully this helps others who may use a raft, and support material (such as PETG for support of PLA), and the settings that help this.
Thank you!!! I’m a noob, but yours was my experience as well. So it’s good to know to just give up on raft. It didn’t even come off well with a belt sander !!
On my first print, the center of the letter “C” (the letter is cut all the way through as a void from top to bottom) curled up- eg, the center portion of the “C” didn’t adhere to the build plate well. So, I added RAFT, and guessed at some values (mostly the presets). Then, on the second print, I got raft, but the raft was “welded” to the bottom. I made some adjustments to the raft settings (reducing the thickness) and on the 3rd print, it is still “welded” though semi-see-through lace across the bottom. It is not coming off and it is tough!!!
When you suggest using “brim” instead, is a brim just around the outside of the entire model, or will it brim the little piece inside of a “C” (or A, or O or R) which is itself in the “inside” of a model?
You have choices.
Found in the “Others” tab.
Screenshot 2025-03-13 at 01.37.54
You can make this global, or if you select the model, go to the Objects Panel (in the Prepare Tab), you can change the options in the bottom section that only applies to the selected model.
Thank you so much !!! :sunglasses: :sunglasses:
Which printer are you using, with what material and build plate? Is your bed level/zero set correctly? Requiring a raft for any reason typically speaks to a plate/material mismatch, an unlevel plate, or an incorrect plate zero.
Thanks for question.
Sorry for the delayed reply. Using Bambu PETG HF, PS1 (auto-leveld), standard PEI plate. I don’t know that it “required” raft, I was just trying to make the little bits of plastic inside of the letters (A, O, R, C, …) not get messed up. The rest was printing / sticking fine. I’m new. Raft didn’t help / couldn’t remove. Brim fixed it.
