Raise Model Z height?
I’m trying to raise a model off of the build plate. I click the MOVE button, then drag the Z arrow up to where I want it but when I let go, the model aways drops down to the build plate. Help please
Bit of an odd request without knowing what you’re end goal is.
There is a work around it seems. If you have a model/primitive on the build plate, click on it, then right click and Add Part/Load. Select the stl/step you want to move off the build plate. Your model will import and you can select where you want to place it. The one issue is that once you click away it will lock the position of your model to the model/primitive you used to import it.
Thanks that should work. I have some letters I’m trying to fit into letter holes in a model. The assembly command doesn’t work so I thought this might be a work around.
