During mid print, about layer 8-12 maybe just finished that layer, it just moved to the chute then moved to the cutting area, cut filament then AMS rolled back the roll. Right after that, AMS started feed the same roll again. The printer purged very little (probably because of the same color) then it continued printing like nothing happened and finish the print. At that layer, there is nothing special, just perimeter walls and honeycomb infill, the previous and the next layer is the same as this layer. When the filament cutting happened, I notice there is no tension at the AMS port from the filament roll, just the right slack of filament. So I can rule out that there was no filament tangle on the spool. The print success anyhow but it triggered somewhat anxiety for something random will happen again.
The print is just single piece, about 5mm height, rectangle shape 300x400mm. Project file started fresh from empty with custom PETG profile and slow print profile for the PETG i am using. Then add one single STL file with one single object then slice and print. Printing using AMS, filament cheap no-brand PETG, only single color, no support.
This incident happened about 3 hours ago right after I rolled back from new fw update 01.07.00.00 down to 01.06.01.02
I had filament tangle on the spool multiple times before and it pretty much jammed the spool tight. I don’t think this incident is about mild tangle and it fixed the tangle by roll back the spool and feed in again.
Did you guys have this “problem” before?
I suspect it could be a SD card problem, but not really sure. Since the incident, I printed 3 more times but it hasn’t happened again.
Sorry, I didn’t take any picture or video for that mater. I didn’t have the phone with me while it happened.
Back of the story:
It happened once before but I didn’t give much thought about it. Early this morning I got massive spagetti, right after I updated to 01.07.00.00.
When I load the 3mf project in Bambu Studio to check if anything wrong with the profile, the filament changed from custom PETG profile to Generic PETG profile and the PA value (device tab) change to default 0.020 instead of custom PA profile of 0.040. The custom PA profile disappeared from dropdown box, but still there in the Flow dynamics Calibration Result window. The original 3mf project was from Makerworld, with PLA profile and massive different settings for each object in the same plate. I changed the setting back my custom PETG profile of course and print speed setting as well. I haven’t updated BambuStudio but just updated newest firmware on P1S last night before starting the print and turn off computer for bed time.
The Generic PETG profile was too fast and too much cooling for the PETG I’m using and caused layer delamination, unlike PETG - as we know - has the best layer adhesion compare to ABS/PLA if print correctly.
It’s just weird that fw update on the device could affect the settings on Bambu Studio. I am embedded software eng and also PC app programmer, I wrote PC app that connect to STM32 via BLE for my current work, but still I couldn’t speculate how this happens with the mess up of print profile and settings. Thus I didn’t want to investigate this problem, just moved on and rolled back the previous firmware 01.06.01.02 and pretent it never happened. Then it startled me with the random filament cutting during mid print, hence this topic.
It happened twice that I know of, maybe happened more before but I didn’t be there to notice.
The moral of the story: Don’t update firmware unless neccessary. Don’t trust print profile from Makerworld unless you have the very same filament and printer as the designer of that 3mf print profile.
