Been having a painful experience with my h2s recently.
The problem happens when the material is running out ready to swap over to the next spool automatically.
Essentially I am waking up to a problem that says the ams failed to retract filament and I will have this amount of material left on the spool.
I don’t understand why the ams is trying to retract at all? Surely the whole point is it’s going to use up the last of that material then switch over to the next spool automatically, which sometimes it does without fail like yesterday it did.
But on a few occasions it’s been happening, itsl seems to be more so with these spools of material.
Pretty annoying as I was up at 4am to swap over this spool manually which the printer should do itself.
This is the amount of material I’m getting on the spool that should have run out completely.
How is the end of the filament secured? It needs to be fairly loose. Ideally, it should be held in place with a small piece of tape that comes off easily, allowing the filament to release from the spool automatically when it reaches the end.
Does this manufacturer handle it that way? If the filament is secured too tightly, it can cause problems when the spool runs out.
I also noticed that the cardboard core seems to be missing from the spool in your photo. One advantage of a cardboard core is that it makes it easier for the AMS to peel off the end of the filament - respectively the tape - when the spool runs out. This can be more difficult with a plastic spool.
Had this thing happen with BambuLab PLA basic yesterday.
In essence the printer didn’t switch to the next roll of PLA of the exact same color I had loaded for that purpose. But instead there was like a meter left on the old roll with a few turns of it still very loosely around the cardboard. It was detached from the roll completely. It was still loaded in the printer but could be pulled out by hard trivially easy.
Sad to have it sit like that waiting for me to get home.
Why it would not continue printing till it fully ran out and instead tried to rewind it is a mystery to me. There’s was absolutely no reason to rewind/unload anything at all: it was a large monochrome print, I knew it would run out, so added the next kg of filament ready for that. no support no nothing to change anything for the entire print: just continue to print even if the filament detached too soon from the roll would have been enough.
When a filament change occurs the filament is pulled back by the spool turning backwards in the AMS. The problem occurs when the filament detaches from the spool and the spool just spins without retracting the filament. This throws an error as the filament is blocking the next filament from being loaded. This is why Bambu filament ends are taped to the spool. This can also happen because the spool is slipping on the rollers which third party or empty Bambu spools can do.
If there was no filament retracting there won’t be a “Failed to retract” error. You may have run into a filament failing to feed because of filament binding or tangled.
If you have filament swaps… and the spool gets close to the end but not fully finished, when it tries to retract the spool just spins if the end of the filament is not secured to the spool properly, and you get that error.
If however the print is all one color, then I am not sure what is going on.
But that’s the whole thing: just 1.5 or so loops left around the spool: no way for that to tangle at all. [Spool was on it from new, never taken out of the AMS once it was put in] And it was detached from the cardboard spool: no way it needed a lot of force at that time.
All I can think of:
it detached from the cardboard a bit too early and the AMS+printer decided there was something amiss as the spool stopped rotating while it fed the filament (but this happens all the time when a spool runs out - might be just for a bit longer than usual) and decided to retract or so and that then failed.
The tape stuck too strongly to the filament at the end causing the printer to assume feeding issues and then somehow the tape managed to detach anyway but only after it had wound back for about 1.5 turns already. Feels a bit unbelievable.
Sadly I’ll never know what exactly happened, nor why the printer decided to retract without any obvious reason. (full tray of identical single color items).
FWIW: H2D Pro, most recent downloadable firmware, LAN-only mode - no Internet for the printer, newest Bambu Studio (just days old).
I’m more worried it’s something in what Studio generates that’s different in this latest version and it’s more sensitive to failure near when spools are about to run out.
Spool was bought at most a couple of months ago - I use a quite a bit of BBL PLA base in white and always take care to use the oldest spool first when picking the next one to dry.
Thanks for that, was meaning to reply yesterday. Yes its held on with tape directly to the spool. This is a latest generation JAYO re-useable spool if it correlates to anyone else having a similiar issue.
It was only on these spools that this has happened.
I think this is exactly it, I believe the printer thinks no something is wrong here and snagging so I’m going to retract the material but it can’t fully.
What I don’t understand is why the material was also removed from the spool on my situation. That part doesn’t make sense.
Just to add to this, this was a single colour print - going from a black spool to a black spool.
