Recommended Profil for: extrudr PLA NX2 MATT 1.75mm (1kg) Filaments
Update:
Very very important: As the users mentioned below it makes no sense to take over some kind of printer settings from others in this forum.
Install the Orca Slicer, which is basically 95% the same interface as the Bambu Studio slicer tool and follow the Carbon X1 calibration video here:
My old post:
Hi guys,
I heard very good things about the following filament and want to give it a try:
extrudr® PLA NX2 MATT ø1.75mm (1kg) ‘SCHWARZ MATT’ - 3D Drucker Filament - Made in Austria
My settings:
  • 0.4 Noozle
  • 0.20mm Standard layer height
  • Textured PEI Plate
Based on the information I garthered so far, I have the following setup. Any suggestions for improvement?
I use a lot of Extrudr with “Generic PLA”. At my last 2-3 kilos i had no problems. But i would not say that there aren’t better parameters for this filament.
Best way to be sure you have a filament dialed in is to run a set of calibrations and then save that for the future. Much better than something someone else shared as there’s a lot of small variations between machines.
I always add the color and nozzle size to the name, as settings for a .4 nozzle don’t work on a .6 …
Like:
extrudr® PLA Blue .6
Are you running BL Studio or SoftFever’s OrcaStudio? If you don’t know about that read this:
https://forum.bambulab.com/t/psa-up-your-game-studio-softfever-orcaslicer-arachne
Cheers!
I am using Fusion 360 along with Bambu Studio. Bambu Studio is amazing.
I use F360 too. Complicated but fantastic.
Bambu Studio is amazing. OrcaSlicer is that same software with added features like additional Calibrations, specifically what you were posting about. :grin:
Did you read the post I linked?
Here’s the Calibration page I mentioned. Using it is drop dead simple as he has the settings perfectly set to run each test with 3 clicks. Choose test, Slice and Print. It doesn’t get easier than that and it tunes your settings and machine perfectly instead of guessing.
I’ll be happy to help you if you have any questions on getting it going! :+1:
Running through the OrcaSlicer Calibration I am at 1,027 flow ratio and 0,004 pressure advance. Density is 1.3
Vitrification temp 60 ish more likely.
215 for all layers. The X1C json profile they sent out to me has 65C for HT and Textured PEI Plate. I use these presets.
I think it’s just an upgraded PLA. For more homogenous look on the top and outer surfaces the print speeds need to come down. I am not at a satisfying level yet.
I have contacted their support, which tbh hasn’t been a lot of help. You’ll just have to try on your own.
Did you try turning on Ironing? (In the Quality section). It runs the printhead at a lower temp with a trickle of filament feed back over the top surfaces and fills in the layer lines for a smoother finish.
Sometimes needs a bit of trial to get the perfect settings but it does help with a lot of prints.
These are my updated settings for the filament in Bambu Studio.
I did some test prints and they look quite good:
However, I am not sure about these settings. Any idea what to put here?
Note: Be careful if you use a bed temp of 60 degrees celcius or above: If you use support filaments, then not all of them run highter than 55 cesius bed temp. The offical support filaments from Bambulab can be run at max 55 dregrees celsius
Generally the default settings for fans and cooling are fine. The only time you usually need to mess with them is if you’re experiencing layer failures. Too much air flow causes layers not to stick, too little you get ugly layers and melting.
It kinda varies between models; a part with lots of little details needs different cooling than a large solid item that’s all smooth flowing curves.
Great tip! I forgot that, glad you reminded me - I’m about to do some stuff using support material. :+1:
For PLA the stock settings are usually all very usable. But there is always one setting I do change, Max Volumetric Flow. I would set it to 20mm/s and test if it still works. Print a volumetric flow test to see what the max setting is that you can still print with without loosing any quality.
Raising it from the stock 12mm/s will make your larger prints quite a bit faster.
This is the way! I am currenlty calibrating my Carbon X1 with the Orca Slicer calibration tool.
Its very very easy to do that and here is also a YouTube video how to correctly calibrate your Carbon X1:
This is the Way. :upside_down_face:
That’s a good vid. I’ve previously done all the tests on another printer and was delighted to find OrcaSlicer had them built in. Sooo handy.
Have fun!
Yes, filament temperature compatibility is important to note, but you can also use a different material for support bases and just use your support filament as the interface. Saves on expensive support material.
That even speeds up the printing time massivley. I made the mistake that I selected base + interace the support. I saved almost 1 hour printing time, selecting base = PLA and interface = support.
That it does! I just had this get me even though I new better!
I never considered any speed difference, but I’m glad to know that it’s faster! I was more interested in it being cheaper. lol
When you use Support material it takes what would be a ‘single filament print’ and makes it a ‘multi material print’, so it’s much slower since it has to purge the nozzle many times and also do a purge tower. Much slower.
One thing I noticed that will let you speed up is really dialing in your filament by doing all the calibration tests in OrcaSlicer. I took a simple print that I had for PolyMax PC that was really dialed in and switched to Ludicrous Mode after the first layer.
It took a 1 hr 42 min print and did it in 1:04, IIRR. Forty mins savings on a 1:42 print is pretty amazing. It came out nearly perfect. There was a bit of a poor detail on the seam, but I played with the setting when I printed a second one and it was better. Not perfect, but this wasn’t a decorative item.
I’m sure Sport mode would have been near perfect.
As i found out today, Extrudr did some work for us…
Printsettings BambuLab
Maybe this helps a bit
That’s all that is in the config file:
“filament_settings_id”: [
“Extrudr_PLA_NX2_MATT_@BBL X1C”
“from”: “User”,
“inherits”: “Bambu PLA Matte @BBL X1C”,
“is_custom_defined”: “0”,
“name”: “Extrudr_PLA_NX2_MATT_@BBL X1C”,
“version”: “1.5.0.19”
It basically uses the same settings as “Bambu PLA Matte”. It works great though and looks phantastic.
