Reduce filaments to those used in the file
There has always only been the ability to click [ - ] to delete the LAST filament added to the filament list, but no way to remove any others. This is extremely frustrating especially when working with models that have color painted onto them as opposed to solid colored merged parts or individual elements. In addition, it makes uploading models to MakerWorld more difficult, because we may have for example, filaments we’ve added as custom filaments - which cause uploads to fail, but without a way to ‘flush’ the file of custom filaments or gcode, other than to be forced to upload a file with several fake filament duplicates.
Please build in:
  • An ability to remove any filament from a file in Bambu Studio
  • Re-order filaments in the list
  • An easier way to debug *.3mf files for upload to makerworld (e.g. ‘strip’ gcode and filament customizations)
  • Undo to affect filament changes and syncing
  • Swapping filaments that are currently in a model, to be swapped with others.
Thank you!
I have the same issue.
I only use a few filaments, but i have to scroll true the long list every time to choose the right one.
This is very annoying.
I was expecting that if you uncheck the filaments you don’t use in the filament list they will not appear in the long list, but that does not work.
