Every plate print includes a “reference block”. Always the same surface area and height is equal to tallest object. I can’t delete it. Printed same file with a different machine, no reference block. I assume my set up has a default setting causing the extra item printing. Any suggestions to get rid of the extraneous object would be greatly appreciated. I hate wasting filament.
Are you talking about the prime tower ?
If so in the process settings - click on the others tab - turn prime tower off
Thank you. I think prime tower is it. Will try that right now.
