Refill has firmware problem
Does anyone know why all of a sudden the AMS on a P1S when using auto refill isn’t working right? Use to work great, but now when you get to the end of a roll it first tries to unload the empty roll leading to failure as it’s already past the point of pulling it out. Use to just switch without problems but last 2 times this is what I have.
If you’re on the P-series public beta, I’d try the same auto-refill path on the latest stable firmware before calling it a bug. The unload-before-refill step also fails once the tail has already gone past the AMS hub or the rear buffer, because the unit is then pulling on filament that isn’t there. Check the PTFE and the buffer for a leftover stub; if the end is gone, clear the path, load the next slot once by hand, then try auto refill again.
/Nils
