We have an AMS but typically use a big 3kg spool instead. Its annoying to have to remember to uncheck the “use AMS” button every print job, or else it gets a fail due to not being able to pull out filament from the extruder. Software should remember last selection, so in my situation it would be off by default.
Until this is build-in into the official BS-application you may try SoftFever. There it remembers those settings from the last time.
thanks for the suggestion, we will add this logic soon
Thanks. Found that a quick fix was just to disconnect the AMS cable while using exeternal spools, as it removed the option.
