Remix Permissions Issue
I’m looking for guidance on how to publish a modification to an existing MakerWorld model when the original creator has explicitly granted permission, but the upload process still prevents publication.
The original model is Anti-Roll Security Wedge for Trailer Jockey Wheel, by dercl0wn.
I made a modification to the underside of the model, adding drainage and airflow channels intended to prevent moisture from accumulating beneath the dock.
Before attempting publication, I contacted the original creator because the model’s current license does not permit derivative works. I explained my modification, my intention to publish it with attribution and a link to the original, and explicitly requested permission.
The creator replied:
“Darfst du gerne machen. Eventuell drucke ich es mir dann auch nochmal neu :)”
Translation: “You’re more than welcome to do that. Maybe I’ll print it again myself then :)”
Despite receiving this permission, when I attempt to upload the modified model using the 3D remix model option, MakerWorld displays the following message:
“Remixing is not allowed by this model’s license terms.”
I want to publish the modification while properly crediting the original creator and linking to the original model. I do not want to classify it as an original creation when it is based on another creator’s work.
Is there an approved process for publishing a creator-authorized modification when the original model’s license prevents the normal Remix workflow?
I would appreciate guidance on how to proceed.
Thank you!
Since you are already in contact with the creator, I would ask them to change the license that the model is under.
Can’t you publish it as a print profile under his original model?
That still breaks the SDFL. Chances are, they will be fine unless someone decides to report.
Looks like someone hid your reply, but the info in it is useful. Thanks.!
