Remote not powering
Hi to everyone, this is my first post.
I received the CyberBrick base kit yestarday and started building the remote controller, followed all the intructions perfectly. As soon as i tried to turn it on the white led on the receiver shield turns on and the fades off not powering the remote. I tried all the core to exclude some problem witht the board itself, same thing with the shield, tried both but nothing. The Cores and the Shields work perfectly beacouse i tried powering them via usb c and they work perctly. What should i do?
Thans
If they power up properly from the USB connector, then I would recheck your ‘perfect’ wiring in your remote. Something it amiss.
Did you charge the battery.
Limit to 3 posts in one topic? So I moved to this one as I am still working on my issue.
I have one of the remotes apart. Disconnected everything and essentially started over. Connect one joystick to the 1 and 2 ports, connected the other joystick to the 1 and 2 ports, yes they are different orientations based on the side the joystick is on. Connected the button, then the switch, then the toggle.
What I expect to happen, the right joystick will operate the side to side controls. This part works. The left joystick should control the forward and backward. This one does not operate at all. The tracks turn as soon as I link the bot and controller together. There is no slow down, speed up, changing directions… nothing. It just feels dead. Like there is no power or anything getting to it… if that makes sense.
I can understand if it was only one of them, disappointing for sure, but for both of them to have the same problem, I feel that this is something that has to do with the boards.
I tried to reset the boards (hold the 2 buttons down then add power) and downloaded the configuration again and still no luck.
Thank you for your help TomWS. I really do appreciate it!!! At least I have made it this far and sort of deducted that it could easily be the program. maybe…
What is moving side to side? I thought this was a tracked device. Turning in that case would be differing speed on the tracks…
Are you using rechargeable AAA batteries? According to the spec sheet they do not provide enough voltage for the board. 3 of them only provides 3.6v while the board needs 3.7v.
Frustrating to learn for me since I don’t own any alkaline batteries.
The controller boards appear to eat batteries like kids eat candy. I’ve already burned through 2 sets of 3AAA batteries in about 2-3 hours of controller being on.
Yeah i mean that would be obvius, why dont’s use the same rechargable battery as for the machines?
Well, the AAA batteries are rated at 1250mAH, the rechargeable one is rated at 700mAH. Now there is a switching power supply on the core, but…
Switch to AA (2850mAH) or a Wall Wart.
It isn’t a limit, it is a recommendation. You can just dismiss it.
The aim is to foster joined-up thoughts rather than operating them amongst many others. Its 3-entry rule (suggestion) isn’t always right.
Just think, am I writing too many separate posts when I could have edited a previous one?
If the three in question are separated, it doesn’t make sense to me to go back and edit the most recent one, especially if others have posted since.
If you have written three in quick succession, use the edit button as it is cleaner.
Are you hard-wiring everything together inside the generic remote from CyberBrick?
If so, you may wish to use a prototyping version designed to debug issues.
This one is mine.
This one from @Josh-3D.
You use one of these to easily connect and disconnect parts to work out where the problem is.
If only there was an edit button. I tried that too. I wanted to go back and add to a reply, but alas… that didn’t work.
The right side joystick works as intended. If I push to the right, the right track will stop then slowly go in reverse and the left track keeps going. If I push the joystick to the left, the opposite happens.
The Left joystick should operate both tracks either forward or backward depending on which way you push. It doesn’t do anything. The bot just goes forward without pushing anything. It will turn with the right joystick, but it doesn’t stop or go backward. That is the issue.
Do you have a rocker switch on your remote?
If so, try flipping it to the opposite direction. Call it a WAG.
The edit button on your posts.
Screenshot 2025-06-02 at 23.38.02
It looks like you are still set as a new user and have yet to obtain the trust level of basic, as you have not completed the minimum requirements.
Trust Level 1 – Basic
At Discourse, we believe reading is the most fundamental and healthy action in any community. If a new user is willing to spend a little time reading, they will quickly be promoted to the first trust level.
Get to trust level 1 by…
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts
I think it finally changed me to Basic. I read a lot of posts, just because I like to learn new things.
  • 2 days visited
  • 1h read time
  • 9 topics viewed
  • 83 posts read
I have the rocker switch and tried switching to all of the positions. I use Energizer AAA batteries and have changed them twice. As mentioned in an above post, these remotes eat some batteries. Maybe I will print one of the prototype controllers, that way it my desk doesn’t look like a rats nest of wires and switches and stuff.
I haven’t experienced it yet.
I have used both the battery pack and the Li-ion battery as the power source.
I have confirmed that you have achieved the basic trust level.
That’s what I was observing too. This is really frustrating when the remote is dead every next day after having recharged the batteries. I use Eneloop AAA 800 mAh (https://amzn.to/43rII5R), but no other devices burns through these like the CyberBrick boards :frowning:
That sucks, they should have provided similar battery for remote like the one came in the kit.
Hello, i’m experiencing the exact same issue with the remote. If the batteries drop below 1.5V, it just won’t power on. They really have to be brand new. After just a week, I already have to replace them, even though I’ve only used the remote 3 or 4 times…
Could this behavior be fixed through a firmware update? It seems like the power management is a bit too strict.
Just sharing the response I received from Bambu Lab support:
Hello there,
Thank you for reaching out to us.
Thank you for your feedback. It’s true that AAA alkaline batteries tend to have a shorter lifespan. We’ve uploaded a new print profile under the official remote control model, which includes a redesigned battery cover for use with lithium batteries—this version offers extended battery life. You’re welcome to give it a try.
Additionally, you may also consider using rechargeable AAA batteries for a more sustainable solution.
:link: CyberBrick Official Standard Remote by CyberBrick MakerWorld: Download Free 3D Models
