Remove certain support (after slicing)?
Hi there!
I recently purchased the A1 mini and I’m absolutely love it.
Having some experience with a Felix 3D printer (felix 3), but the mini is so much beter…
Started slicing and was wondering if it is possible to remove certain support since there is no need for some parts to have support.
See picture below:
Is there some way to remove these (indicated by the arrows) but keep the others?
You can add support blockers there.
I learned just a few days ago that you can also add a support blocker with a right click on the object and the addition of a primitive shape or a custom model:
Awesome! Thanks for sharing this guide!
Same here… learning on the job :stuck_out_tongue:
Thank you!
To confirm…
The ‘support painting tool’ works perfectly! :heart_eyes:
Is there a similar method for the Infill? I created a drawing with a void for a magnet but the infill is populating the void I created. I cannot turn Infill off due to needing Infill in other areas. Thank you
On another note is it possible to delete certain lines after slicing?
Hi @WereZombie
Welcome to the forum.
The feature you seek differs from the topic, so it would be better to start a new post.
In any case:
  • If properly done, the slicer should fill the void spaces, e.g.:
    What software are you using?
  • You can also do it in BambuStudio, but it may be challenging for complex models. E.g.:
    1. To open a void space, e.g. for magnet insert, into an existing solid print;
    2. Right-click on the print file, select “Add part” or “Add negative part” and choose the correct shape for the magnet;
    3. Scale the added part to the correct dimensions;
    4. Position the added part within the original print file, i.e. in the place where you want the void space;
    5. If you selected a “Add Part” in 2, subtract it from the original print file using boolean operations, specifically the “Difference”.
    6. On the other hand, if selected “Add negative part” in 2 , you can skip step 5. In both cases, the results entail the look for void space.
Note: steps 3 and 4 require selecting the correct object using the Objects Menu.
I was also struggling with the same problem. The solution I found was to got into the “Support” drop down on the side and select either “On build plate only” or “Support critical regions only”. Both of those work for stopping it from building in supports in the negative space for a magnet.
I couldnt get the support blocker paint tool to work on an internal void, despite doing it correctly. but adding a support blocker primitive worked perfectly. I dont know why. Maybe because the void is internal and cant be reached by the painter tool?
Closed box:
Rotate to view from the bottom and select Support paint tool:
Use Section view to see inside the top; paint blocker on left side:
