Removing failed items from plate during printing?
Hi, I thought i had read somewhere that if one item out of say 15 on the same plate started to fail you could isolate it and prevent the printer from trying to print it and causing all the others to fail. Is this not the case? If it is how do you do it? Thx
The pause button shows 3 squares, touch it and it lets you pick the object to exclude.
Cheers Duane much appreciated, does this need to be done on the printer or can you do it via slicer or handy app?
I’m not sure, I don’t use the app
hi everyone - im a bit confused - as far as i remember i used to have these three dots on my mobile phone app - but now i always have to go to the printer.
Did they remove this option - or am i remembering it wrong?
Would be super nice to cancel some objects from the mobile app - as my printers are not running in my home and i always have to drive 10 mins to get there…
Thanks and greetings from Berlin,
Peter
I just did it, this is amazing !!! I love the option thanks for the tip
This is such a cool feature but is it only available in the app?, I cant see it in the desktop app
It’s also available on the X1C screen.
this is the way to do it ty sr
does anyone know how to do this on P1s
nevermind I just found out
Just want to say one thing about this feature…
WOW!
FOR THE p1s. You must pause the print in the (Mobile) app first, then a icon next to the pause button will appear, with an arrow and 3 dots. Click on that and it should show you the menu to remove any object!
do note that the object has to be seperated before you slice it; if its all one peice of geometry, you probably cant exclude parts of the geometry.
I just did this on my P1P. On the app pause screen, select skip. Then it will bring up a layout. You just click on what you want to skip. I was printing 23 minis. 1 broke loose and took 2 with it.
In the Bambu Mobile App, you have three options while printing:
Skip, Pause and Stop Print. Click on the Skip Button. You can select the Object to ignore there.
Hope this helps!
thank you so much! I was trying to print candy canes and snowflakes (forgot to enable support) Was able to skip all the failed snowflakes and save my candy canes
You are my hero. But by just writing, you found the solution, maybe others did not. This is quite selfish, my friend. Perhaps you could share your solution with us?
Thanks you so muchhhhhh !!
when I tried this on the app it said not possible on Bambu slicer below V1.6 …but mine is V 2.1 !
there isnt an option to do it on the (A1) printer screen
Thank you, I hope they will add it in the Pc version too, this just saved me 2h and 5 good parts.
