Removing glue stick
HI, I never used glue sticks before, maybe because I never printed ABS and ASA before.
what is the best way to remove to glue remainings on the printed ABS Objekt and what is the best methode to clean the high temperature printing plate from the glue stick left overs.
I tried Isoprpopanol 99% but its getting messy, I only get a sticky surface all over but not the cleaning effect I would like to have.
Warm water on the print
Warm water and dish soap on the build plate
i use isopropa and the scraper , the scraper with blade it takes all the glue you can scrapp it very easy of and if its clean enough 1 paper towel to dry and clean thats it, but warm water and dish soap does it too but tales too long for me i use the scraper soluttion, i also noticed if you glue it view times yo dont need to wash off just use no more glue and print on. sticks very very well.with old dry glue on cold plate.
Warm water and a paper towel takes all of the glue stick off with no scraping. It will come completely clean and dry.
I use the Same
Water on object
Water and Dishwashing detergent for buildplate
one question, do you have a Link to the blades? i can not find blades which are fitting.
ohh you was faster ^^
Perfect, thanx !!! My wife loves this ( and I love my printer :wink: )
