Removing ink from PLA
Hi, does abody have any tips for removing ink/paint/blood from PLA prints? Ill occasionally get some ink or even a bit of blood when removing supports (sometimes the paint from the pliers or knife will leave marks as well), and end up having to scrap the print as I cant remove it afterwards. Would anybody know of a substance that would help remove it?
I cant use sandpaper as im using the prints in their raw state without sanding or printing.
thanks for any advice!
ps. I do have finger protectors that I sometimes use when removing supports :slight_smile:
I have different flavors of needle nose pliers I use to help remove supports. I use fingers for the big stuff but those for things stuck harder or harder to get to. Sometimes a flat blade screwdriver to scrape with.
On getting blood off the part, I wouldn’t use bleach since it might affect colors and even the plastic. I’d try the enzyme wash pre-treatment sprays used for clothes. Can’t say for sure they’ll leave colors alone but I’d bet so.
oh! sounds interesting, ill look into it thanks
Blood should come off plastic with plain water.
In the shop, the first thing I reach for to clean things is 90% IPA, mainly because I always have some near the printer.
IPA will clean up almost anything that dissolves in water and some things that need a mild solvent. I’ve used it to remove blood, glue, some inks, permanent marker (Sharpie), pencil marks, some label adhesives, and uncured paint.
Whenever possible, I hold the print on a cutting board or wood scrap to clean up support marks. It’s more stable and the danger of a knife slip is much less. Flush cutters and a deburring tool also reduce the need to use a knife.
Peroxide is my ‘go-to’ for cleaning blood from anything.
I’m gonna come at this from another angle and mention that you should invest in some cheap tools instead of spend blood, and use the tools!
May I suggest a $25 shopping trip:
2 Deburring tools, one with a standard blade, and one with open end
Forceps
Needlenose Pliers
Plastic Razors
2 Flush cut snippers, one to keep sharp and one to abuse
Wedge spudger/pry tool
Gloves of your choice, I like (clean) rubberized garden
thanks :slight_smile: yeah I have all those - except a pair of gloves - which I should really buy :+1:
It’s real easy with sharp tools and stuck parts to hurt yourself permanently. We all can think of various handicap levels of injury, but consider avoiding the more minor things too - “this finger now hurts forever if I push on it like this” is not exactly a great fate either! Especially if you’re older than 50, those ligaments and tendons stop healing correctly lol.
just bought myself some gloves :+1:
