Removing the INTERNAL Back Cover of a P1S
I was upgrading from Steel to Hardened Steel nozzle / extruder.
Was finishing re-assembly, when I accidentally dropped a screw from the nozzle into the printer, that somehow bounced back behind the pannels that are to either side of the rear Z-Lead Screw.
Before I knew, I tried tilting the printer slightly just to check cause I couldnt see it. And I could hear it roll for about a split second before ending up caught on something.
So I thought instead of performing a brick-in-washingmachine maneuver I’d remove the internal pannels first… but how?
Or would the outter rear panel give me access also?
I ended up opening the Outer Back of the printer instead since I found no way to open / remove the inner pannels- it also grants access to the exact same area and is probably the easier method to work with anyways.
Maintenance and How To guides | Bambu Lab Wiki
Im aware of this page, and have looked through it ahead of time when I made my comment.
Unfortunately, I do not know the name of these inner panels, making searching difficulty. Or maybe I was just unable to see the tree for the forest after looking for an extended period of time.
Id appreciate it if someone actually found the link in the wiki that would show instructions of how to use it, or at least name it so that I may find it outside of the oficial wiki. Though the problem had been solved, im still curious to know more.
