I know I moan a lot on here but just want to give credit where credit is due and say a big thank you to all involved in getting the repair model feature finally working on Mac! Top stuff ![]()
Is there a new release for macOS?
I had a warning just yesterday saying a file could only be repaired using the windows version of BS.
I fixed the actual issue I had caused rather than using a repair.
I run into needing to repair a model from time to time. Hoping this improves my work flow. Very cool, thanks for the update!
Its only a link. Does nothing, dumps you on the page and thats all. You still need to export the model to STL and then upload manually. PFFFT… Could do better
Oh man, are you serious? I haven’t tested it yet as I haven’t come across the problem yet. So it’s just a website you can use? The way it’s worded in the release notes I assumed they’d collaborated with that website to integrate it into Studio ![]()
I had hopes, loaded a step file from fusion today and the fix balloon popped up. Clicked the link at the bottom and just opened the link in safari, no referral or anything. I really can’t understand all the fuss?
It gets even worse…
I just tried using this website for the first time. Was stuck in a queue to be processed. Started at number 114, and 10 minutes later…
Your STL is important to use, and we appreciate you staying on the internet! The next available CPU cycle will assist you as soon as possible.
They must be using GeForce 2MX to process all this ![]()
