Repeated fails (Please help a newbie!)
Hi all,
I’ve had my A1 about 3 weeks and all is going well until yesterday. Fail after fail… To me it seems like it isnt sticking to the plate? Or sometimes it does but then moves halfway through, plus its catching and peeling back up on the edges.
I’ve washed the plate (I tried using washing up liquid and again with alcohol. neither worked) and I’ve run a full calibration. Still the same. My filament is new, and Im using a model which has worked perfectly before so I know the settings are good…
I have no idea what i’m doing :sweat_smile:
I just had a similar issue, really poor adhesion or very thin first layers that wouldn’t come off and lots of clumping, and realized my extruder gear was clogged. while changing it I also realized that the spring adjustment was way too tight and I could not open the extruder holding wheel so that when I was pulling filament out of the extruder, I was grinding the filament through the gear. I replaced my gear and relaxed the spring which is done on the left side of the head. It prints better than it ever has now.
A 3 week old textured PEI plate should still have good grip. The only question would be your cleaning method. You should only use plain dish soap and warm water. Alcohol is problematic and other solvents can damage the plate. Some soaps have skin softeners and fragrances - avoid those like the plague. They can leave residues.
It sounds like you are assuming new filament to be dry. It actually is too wet right out of the shipping bag more often than not.
Those problems look like what I’ve seen with filament that was too wet. Drying it well fixed my print issues. Bambu has a wiki that gives a good briefing and how-to on drying filament.
May not be the issue. It’s hard to diagnose remotely. But with it being a new printer and your prints working until they didn’t, my money is on filament that now has too high of moisture content.
Without the model or a screenshot of the slicer we’ve got no idea what that plate is actualy trying to build
So the following is a guess:
If those are supposed to be simple shapes (cylinder on top, three rectangles below) there appears to be a problem a couple layers up that is causing layer shifting (to the right, approx 1cm)
If this happens more than once, its almost always because of something interfering with the head as its moving. Have you installed any mods on the machine, or placed anything near the machine that it could strike? How are the PTFE tubes, are they freely moving, or are they pinched and binding on something?
Don’t use alcohol on build plates, it never works for me and I have ruined some plates with it. Soap and water or a new build plate
It doesn’t look like the plate has moved, and step loss detection tipicaly catches that pretty well
This is also a multicolor print, are both materials the same? (Pla and pla)
