Request: Comparing VFA A1 vs X1
Request:
If anyone is willing to print my 15 minute, 4g model and share the results here, it would be really helpful!
I’d like to compare the VFA characteristics of A1/A1 Mini vs X1 printers.
I’m specifically looking for the vertical lines that show up for X1/P1 across the X axis.
Files:
A1 Mini_Bi-Directional VFA Test.3mf (101.9 KB)
A1_Bi-Directional VFA Test.3mf (98.8 KB)
X1_Bi-Directional VFA Test.3mf (99.3 KB)
This is what it should look like under the “speed” color scheme.
Explanation:
I’ve been struggling with VFA on my KS X1C for over a year and it’s severely impacted the quality of prints I do using transparent PLA especially. I want to figure out if getting an A1/A1 Mini would solve my problem without compromising other elements of print quality.
Still hoping somebody will be willing! I can pay a little to more than cover costs to do a test. Really want to find out if the A1 (or mini) can beat the X1 in this regard.
No infill is ideal - the issue I’m working on is a ripply outer wall surface caused by resonance or belt teeth. If no ripples show up when printing the model without infill, then the problem I’m chasing is not manifesting.
The X1/P1 have it especially on the X-axis. Some people seem to have resolved it by replacing certain pulleys which is a very invasive mod and not guaranteed. I’ve tortured my X1 with almost no change in quality except on the peak resonance band.
Here’s one of the threads about it where I showed pictures of the problem:
The format for the A1/A1 mini is so different I am hoping that it won’t suffer from the same issue and if not, I would get one to print my transparent parts where these ripples are intolerable.
Yes! Sorry, I didn’t understand the question.
Just to make sure it comes through right:
• 1 wall thickness
• 0 top and bottom
• small brim to ensure it sticks
• should be about 8 height range modifiers running from 100mm/s - 180mm/s in 10mm/s increments
This is wonderful! Thank you so much for taking the time to do this test. I can see a hint of VFA on the front of X and nearly nonexistent on Y, but compared to both my X1s, it might as well not be there at all.
I think I saw mention that the A1 series has belt teeth-over-smooth pulleys too, so it seems that the teeth always manifest but this format does it a lot less. It definitely looks uniform rather than having certain especially bad bands as on X1.
This has been extremely informative.
I will probably buy an A1 or A1 mini now. :laughing:
$5 if you’ve got Zelle or PayPal!
I’d be very happy to donate to them! Very kind of you, thank you.
Edit: They have received the donation. :slight_smile:
The A1 mini doesn’t - not sure about the regular A1!
Mini has 1.5mm pitch belts with flat idlers but the belts only have teeth on the section that engages the driven pulley and are machined flat on the area that rides the idler.
This is such a janky solution - I was under the impression they had a smooth section of equal thickness to the teeth which would maybe have less impact. I’ve wrapped gaffer’s tape around my belt to test and seen the sort of deflection it causes firsthand.
Gimmicky solution to a non-issue (toothed idlers are engineering standard and just work)
Why they wouldn’t just use the right parts blows my mind really. I’m also personally really frustrated by the belt fastening system for the X1/P1. Yes, it saves space, but it’s extremely fiddly and I broke the retaining post on my toolhead removing a belt which resulted in having to replace the entire X-axis!
If anyone with an A1 is willing to run the same test, I will extend the same offer for a bit of compensation for time and material or I can donate to the charity of your choice as well!
There are SO many differences between the early X1s and the later ones, this would not surprise me that they changed it at all!
FWIW that’s how it comes out on my X1C, no difference with the various speeds. (the “grains” are because it’s a (poor) glow in the dark filament, closest I have to clear PLA)
Yes there are lines mostly on one axis but to me it’s barely noticeable to the eye unless you’re looking for it and have just the right angle, and the layer inconsistencies in the posted A1 print that aren’t present here would be way worse IMO
Printing at the profile’s standard higher speed is fine too, although it required bumping the temp up a tad to maintain the transparency.
Good points! I have revised the original post using most of your recommendations. Can’t use the Bambu Basic PLA setting because it knocks the layer time down to 6s which caps the speed severely.
Also, you already have a test of the mini - not sure why you ask for another one.
Each of the 4 X1Cs I’ve tested produce different levels of VFA with different speed peaks. It’s possible that a single printer happens to be one of the best ones and could misconstrue the typical quality of the model in general.
Thank you for sharing this. Can you clarify, are these printed on X1, A1, mini? And the different views are different sides of the print? Thank you!
X1C as mentioned, and yeah 2 sides as the model “unfolds” when printed as requested
Great thank you! This really shows the problem as it appears on X1C and serves as a really good benchmark. Mine is really similar to yours prior to any of my efforts to improve it. For most prints not a problem, but if you’re trying to look through something it can be a major problem.
Stil in need of a A1 print?
Yes please.
I’ve read people think the A1 is better, but I’ve also read people having real issues with VFA’s on it. For some reason most people just don’t see them on their own prints, even though I do, so any comparison pictures would really help.
Unfortunately I’ve not been able to find an alternative that I like and isn’t too much of a compromise yet.
PETG translucent clear is useful to you or no? On A1
PETG translucent clear isn’t very clear.
Thanks for trying, it’s appreciated. Unfortunately I can see much from your image.
Is anyone willing to run a VFA tower in Orca slicer? That would easily show any issues. For example, here’s the one from my returned X1c.
I can run whatever you want, question is if that filament is useful.
I don’t use orcaslicer so is there a file I could run easily?
