[Request] Configure printer
I would like to configure my printer.
Like:
Nozzle is hardenend steel or whatever
Housing attached
Internal fan installed
etc.
For instance actually I got everytime I am printing PLA-CF the warning. I don’t want to see it anymore.
No, why are you asking?
because they are removing the SS nozzles from the shop and everything will be HS going forward, when the housing shroud becomes detached the printer will tell you, because its a mechanical failure, same way it would if your extruder was missing, the internal temp regulating fan (if you have one) only works with the X1 series so far, doesn’t mean you can’t add it yourself if you know how to code for the other units otherwise it just sits there greyed out and unclickable. And as for the WARNING if you raise the settings for the bed temp 2-3 degrees C the filament warning won’t trigger anymore. You have really strange requests
The X1 has touch screen configuration of nozzle size and hardened or not, so provided you remember to set it, the printer knows about it. If they can’t bring that to the P1x they really should put it in Bambu Handy or something.
As for internal fan I would assume the printer would know automagically as long as it has closed loop fans. I think the P1P doesn’t?
I upgraded my P1P.
Its not a strange request. I upgraded my printer and I want to enable this somehow.
you enable it on either orcaslicer or BS, nothing is done on the printer interface.
I can? how? Maybe I have overseen some settings.
Hey just an off chance have you updated your firmware yet?
Firmware is always up 2 date.
