REQUEST: MORE MODEL CUT OTPIONS - DOUBLE CUT or CUT OUT
would be awesome to have a double cut or cut out… wich creates thre parts instead of two after the cut!!! so it basically cuts out a whole part of the object…would make resizing individuell areas of a model a lot easier!
You can probably use a “negative part” to do this.
how? i dont understand how this should work…
Here is the wiki for using negative parts.
https://wiki.bambulab.com/en/software/bambu-studio/subtract-a-part
Reading your post again using a Boolean mesh is probably more what you want to do.
https://wiki.bambulab.com/en/software/bambu-studio/mesh-boolean
