and every time I import a model from Makerworld, the Filaments get changed to those of the creator. I then click “Resync” to get my Filaments into place, BUT instead of using my profiles, it always imports the Generic PETG profiles from BBL. It sets the correct color and order, so that’s great, but still the settings are different.
Anyone any idea how to solve this - to not having to manually change all profiles every time I import a file?!
Thx in advance community
PD: Or is there any setting to mitigate the change of filament-profiles when importing any file in the first place??
PD2: Yeay!! and since the new update I have another problem which goes hand in hand with the above situation (if one not changes the profiles).
Happened the third time now. The profiles/colors are somehow not syncing (when default profiles are loaded) and going to print.
Difficult question, simple answer: Create a new printer, e.g. “x1c home” and store all your filament profiles in it. If you now open another Makerworld profile and all your settings change, it’s no big deal. Next time, simply click on your “x1c home” and everything will be back as usual.
That sounds less of a hassle. I wonder why there is no option to not import printer-settings. I would understand the filament-profile, but why colors…? No one has the exact same colors. I’ll give your way a try but still hoping someone has a solution ^^
Instead of working around issues, I like to fix them or get them fixed. Therefore I have already made several requests and suggestions of which some have been partially fixed, and others should be completely fixed with V1.9.
But it has happened in the past that I missed a button I could have clicked, or didn’t fully understand its intended use-case.
Functions might also be useful for a certain user, but creating problems for others.
I just want to be sure I’m not missing anything because for some reason they programmed it like that. I just can’t see the beneficial side of it.
Hello,
Has there been any update to this issue? It’s annoying to have to change my printer back and resync my filaments every time I open a MakerWorld Model or file.
Thank you!
Apologies if I am missing something posted later about this. I am still new to the forum and learning to navigate.
