Would be great to have ability to calibrate retraction distance settings the same way there is a flow rate calibration. What would be needed for that?
You’d need a feature that generated the Gcode with different retractions. This is very dependent on filament, temperature, and the physical aspects of the printer. Perhaps you could try the tool at https://teachingtechyt.github.io/calibration.html#retraction - you’d need to add the start and end gcode,
Yes, exactly! I would see having this feature in BambuStudio as a great benefit since there are so many different filaments out there and easy retraction calibration would be of a great benefit!
Since the OrcaSlicer fork already has several calibration patterns, you could suggest this there. SoftFever/OrcaSlicer · Discussions · GitHub
Good to know, just added a feature suggestion.
