Thanks. The print is still the same. With threads.
Have you dried your filament? Moisture is the most common cause of stringing.
I’m going to do that now and let you know. Thanks.
Hello. I let the filament dry for over 10 hours and haven’t noticed any improvement. I set the filament retraction to 6 cm and 80 mm/s. It’s still leaving threads. Could you advise me? Thank you.
dear god 6cm is basically out the top of the toolhead lol, stop!
Send a pic, words will not be enough
6mm lol
The platform does not allow me to upload links or images.
Whats the 3-dot model supposed to look like? screenshot of slicer or stl/3mf plz
195C is rather low but maybe not a problem
There are three stitches, each 2 mm wide and 0.6 mm high. There are three layers, each 0.2 mm high. I did this just to test the retraction, as I’d been doing a lot of tests and it wasn’t working. That’s why, with these three stitches, I could clearly see if the threads were improving.
I tried new filament, many retraction settings, different speeds and nothing improves.
I’m doing bushings for the fender arches for a Saab 9000 and had some issues with stringing. Tried ChrisMuller’s settings and hoooly moly!! Absolute perfect print for mass production.
Massive thanks for your help!
For anyone who couldn’t find those settings in the UI: Three dots to the right of the filament (under Project Filaments) then Edit, then Setting Overrides.
