Return to main screen after print start
P1P, it would be handy to have the screen return to the main menu after a print job starts instead of staying on the last used screen.
Also, after an unload command and the filament is removed, it would be beneficial to have the printer automatically go to a load situation, as the more likely scenario is that you are unloading to change filaments. Then the print head wouldn’t have to do it’s homing movement prior to loading. And if you are unloading to perform maintenance, you can just cancel the load command.
