Hi.
I got an AMS unit. Is now my second. The required hub is still a long time coming but ok. But one thing makes me think. It is advertised that there are four spools. 1x PC/ABS Alloy Material High Temperature Reusable Spool, 3x ABS Material Reusable Spool. These are empty spools. What exactly do I need a high temperature reusable spool for? Is it necessary to use a high temperature spool in the AMS? Sorry i does not understand this. What is the difference in the AMS unit ? Sorry for this stupid question.
Sorry for my bad english.
Great`s from Germany
the high temp spool is if you want to remove moisture from high temperature filaments like ABS and CF
if you use a ABS spool to dry abs then the spools could melt
so using a ABS spool for PLA works fine , but not for the same material
so a high temperature spool wont melt in that case
Thank you. That makes sense. ![]()
