Printing a lovely modern birdhouse using Elegoo PETG Pro, decided to use Bambu HF Preset on it. Turned out relatively great except for one side has rough texture outside and within. It is also the side with the supports
Why are there issues only on one side?
Should I have stuck with Generic PETG?
Could it a stringing issue? Not dry enough?
Should I look into Retraction settings?
I am also interested in what would cause this. I just ordered some of the elegoo petg pro because it sounds like Bambu petg hf and my hope is to get more PLA like prints with the strength and temperature resistance of petg.
Other than these marks, how do you like the filament compared to Bambu HF? Or how do you like it overall?
I think they just released this Elegoo PETG Pro recently.
The marks could be because it needs to be dried.
I don’t know how to set speed properly in Bambu studio to match a manufacturers instructions. Elegoo says 40-100mm/s… how exactly do you configure this speed correctly in Bambu studio? There are so many speed settings…
In hindsight, it was definitely a longshot to pick a random profile hoping ti work work with Elegoo PETG Pro. I went ahead and went to the calibration tab in Bambu Studio and ran both auto calibrations, created a profile specific for Elegoo PETG Pro. Albeit a different color and different project I needed to print for, this turned out to be the right way forward so far.
Thank you very much, last night I decided to go for broke and just cranked everything up but I missed some of the things you mentioned, my stuff still turned out pretty good but definitely gonna make the changes you mentioned. Thank you again.
I’m getting good results on large prints using Elegoo Pro PLA. No noticeable warping or curling, as I might notice with other PLA’s. It prints cooler and claims to be more rigid than regular PLA, and I imagine both help in this regard.
Makes me interested in trying this Elegoo Pro PETG, but unfortunately isn’t available on amazon, at least not currently if it ever was. I’ve printed a lot of Elegoo Rapid PETG, which is available on amazon and is good for speed, but more susceptible to warp/curling, at least compared to Elegoo Pro PLA.
You should buy directly from Elegoo’s website. I found the prices to be cheaper in most cases as well as a lot more range in colors and filament types. And each filament type includes the specifications that will help you set the filament settings.
Hope this helps.
