Rough top surfaces and ugly lines
Hi all,
My daughter’s birthday is coming up and I wanted to print a cake topper. I played a bit with 3d lettering and then printed it, but I noticed the really rough surfacing. I took in account on the model that it should be in increments of 0,2mm as this was my layer thickness. I applied my standard ironing to it (Top surfaces, Rectilinear, speed 20, flow 30, spacing 0.1, inset 0.21) that usually smoothens out the top surfaces but I still get ugly lines and rough surfaces in some spots.
Does anyone know how to prevent these?
Thank you in advance.
Kind Regards,
Eef
Mije10Jaar.3mf (68,1 KB)
Recalibrate the printers and auto bed leveling should help. When was the last maintenance?
Thanks for your reply!
I do bed leveling on every print.
Last maintenance was on the end of January (Lubricated the z lead screw and wiped down the carbon rods). After that I ran full calibration. I changed the nozzle this weekend.
I ran filament calibration again this morning, it made little difference unfortunately.
But on other prints (not self modeled) I don’t have this issue.
It is overextruding.
Think about it. Your flow ratio is about 95% or 0.95, same for the top layer, yeah? Then you top it up with 30% more when ironing. The excess plastic has to go some where, yeah?
Hi,
I downloaded your file because, funny enough, I was suddenly having the same problem myself. As you can see from a print of your file, I have a rough print.
I tried to think back to when this first started happing, and after a day of rewinding my memory (a great “Black Mirror” troupe, I realized it was when I had to print with a rubber filament for the first time. After doing an initial configuration, and saving it to the printer, I saved it as a separate preset, before eventually going back to printing with my regular PLA. That was it I believe!
When you save a new preset, after defining it during a calibration, it seems to me that the printer is not saving presets the same way the Studio is, but instead keeps only on “K” value on the printer. When you go back to a different filament preset, the printer still uses the last calibration settings saved to it, so if your “K” value is different for the flexible filament, your regular filament preset will still use that, even though you have defined filament settings for each.
To be on the safe side, and to rule out any other config concerns, I loaded me regular, basic pla and configured my calibration to that, and the printer said that it is saved to the printer. I then reprinted your file, and it appears to be correct.
If your have done a calibration recently, especially for a new filament, do it again, by printing the lines, then the square wafers, and save that setting to your printer, before printing you file, with the same filament again.
This is why I like to stick with just one filament source. Usually with my Anycube Basic, I can change to any colour while keeping the same profile. With the flexible filament, it was a different manufacturer and a completely different texture, and that is what I had saved into my printer, before saving the proper one back.
I have had my P1S for a few years now, and I can tell you all, for anyone that is a maker and know their way around mechanical things, I have never had a serious problem with this machine, and consider it a workhorse!
It has never had a problem, no matter how daunting it appears, that I have not eventually been able to fix myself.
But, I never update anything. Ha!
IMG_5173|666x500
IMG_5172|666x500
Hi Wingmaker,
Thank you for your reply. I will check this out in the afternoon and see if I missed something on that.
But when you say that you ‘save setting to your printer’ how does that work? Cause I set the K value in the Device tab and I select the profile for the filament in the Prepare tab after calibration, but how do I get these values to save on the printer then?
I always thought the K and filament profile were going to be sent to the printer with the file (like in the Z-code or something), but that’s not the case?
I have only yet printed with PLA so far, tho from different manufacturers (Bambu, Elegoo and Polymaker) and I have calibration profiles for every manufacturer (and a seperate one for PLA Silk)
Your M print does look good and way better and the way I would want it to be ofcourse!
Whenever you install a new filament, then run the Flow Dynamics/Flow Rate calibration, upon completion, it asks you to choose a preset name, before reporting that the settings have been saved to printer.
The setting saved to the printer, seems to me, that it maintains these flow settings, even if you select a different preset. THIS MIGHT BE A BUG!
When it is said to Calibrate after changing each filament, I believe this means that simply choosing a filament present in Studio, does not maintain all the calibration settings defined in what is reported to be “saved to the printer” and only the last calibrated results are maintained on the printer.
You may want to consider sticking to only one Brand of filament, to mitigate these printing/calibrating issues.
Hope this helps.
Hey Wingmaker,
Sorry for the late reply! I was kinda busy and on holiday.
I’ve tested your suggestion and did both calibration tests, but for some reason I still get these weird artifacts on top of the letters… I even did an ironing test with one of the models on Makerworld and a swap came out nearly flawlessly, but when I tested it on the letters I got an the same issue! Yours look perfect! What ironing settings did you use? Maybe I can fidget a bit with that… I certainly don’t know what I can try other wise as I can clearly see yours are perfect… Thank you in advance
Hi,
Sorry to hear you are still having trouble with this file. Only thing I can suggest at this point, is to load a file you previously printed using your filament of choice. Print that file, just to ensure the file still prints correctly, then delete the object, leaving an empty scene, then import your lettering model.
To speed things up, you can separate your model, clicking on it, and selecting the cut tool to separate the model to a smaller or single part, then print that.
Another thing you can try is, select model, right click on it and select, “Fix Model” before printing that.
If that doesn’t work, try selecting the model, then right click on it and select, “Simplify Model” before printing that.
One more thing to try is to load the lettering model file into another 3D program, like Blender, or search for a free 3D converter software. Once you have your model loaded, you can use that apps cleaning tools, before saving a new .stl file.
If that doesn’t work, try creating your lettering again using your 3d program originally used.
Or, use Adobe Illustrator to plot out lettering before, then exporting the file as “Illustrator Version 8” during the save procedure. This outline file can then be loaded into a 3D program and extruded, before saving as .stl file.
You can also save Illustrator outline file as .svg, before directly loading it into Bambu Studio. The file will import already extruded, and you can adjust the size of imported parts using scale.
Good luck!
