Router access OK but no internet
Only had my X1 for a couple of weeks but every now and then the WiFi goes. On investigation the printer sees the SSID with good signal. Test runs and shows linked to router but internet test fails. Other devices in the same room on the same Wifi find the internet without problems. Only way I can find to restore is to forget Wifi link, set up phone link, connect ok from printer to phone - then redo User signup and binding to printer. Then switch to other Wifi and works fine. Any thoughts? -cos this is really annoying.
I had a similar issue when there was a wifi repeater involved? Are you sure it’s getting an ip address directly from your router? Can you see the printer in the router attached devices?
I’m going through the same. Have a P1s for 2 weeks worked great. Had an update with app and machine this week and lost all internet connection. At first it would fail at connecting to my wifi. Now it won’t find any wifi. And there are several around me.
