Save Your Loose Filament
Have you ever had a loose spool that seemed unusable? Well, don’t throw it away just yet. We have a quick way to save it!
Print this fixture first. Then, check if the filament is tangled or stuck at any position. If it is, we have detailed steps here on how to fix it: Filament tangled or stuck. Finally, use the fixture to screw the filament on a spool. The spool of filament should print as a fresh and normal one now!
If you want to use it in the AMS, the fixed spool might not fit. An alternative is to use a filament holder that can be printed to hold the fixed spool so it can be used as an external spool!
For more detailed information, please see this wiki page: How to fix filament issues caused by unlocked spools
Did you have a loose spool that is too unused to be disposed of for recycling? How did you fix it? Share your thoughts and save more filament together!
Why not just respool it twice if is a bambu spool?
