Scheduled / Delayed Print Start
Hi Bambu Labs team,
I’d love to request a scheduled or delayed print start feature in Bambu Studio and the A1 Mini firmware.
It would be extremely helpful to be able to choose a specific time (for example, 1:00 AM) for a print to begin instead of it starting immediately after sending it to the printer. This would make overnight printing much more convenient and user-friendly.
Having a built-in scheduling option in the software or Handy app would be a great quality-of-life improvement.
Thank you for considering this feature! - CheezIt
Here’s another use case this would address: You find something amazing you want to print, but it’s late at night and you don’t want to disturb your neighbors. With this feature, you could schedule a print for the start of the morning while still being able to sleep in.
Schedule print Stats would also be good for using printers when the cheap rates in some areas kick in, as well as being cost effective it would also be greener
A feature like this would certainly be welcome it would allow for the choice of starting a print during off-peak hours, or early in the morning for those with solar power. I’m using an H2D myself.
Thanks in advance!
Got tired of waiting for this, so I made a workaround that does the waiting on the printer itself.
PrintLater adds a short block to the top of a sliced .gcode.3mf that keeps the printer idle until the time you pick: heaters off, fans off, motors released, then a chain of M400 S90 dwells (a single dwell is capped at about 90 s). After that the normal start sequence runs. You send the job right away from Bambu Studio like any other print, so Handy and cloud printing keep working. No Developer Mode or LAN-only mode needed, and the PC can be switched off after sending.
Tested on my P2S with AMS: an 11 hour wait started within a second of the planned time, first layer about 8 minutes later.
It’s a right-click menu + small dialog on Windows. There’s also an optional Home Assistant blueprint that switches the chamber light off (G-code can’t do that) and lets you know when the print actually starts.
Search GitHub for rgerr/printlater (new account here, so I can’t post links yet).
Keep in mind: the plate has to be empty at the start time, the printer shows as printing while it waits, and you can’t send another job in the meantime. Only tested on a P2S so far, so feedback from other models is welcome.
Update: there’s now a Windows installer, so no Python needed. Grab PrintLater-Setup-1.1.0.exe under Releases on GitHub (rgerr/printlater). It isn’t code-signed yet, so SmartScreen will warn the first time: More info → Run anyway.
