Hello, as a Bambu newbie, I have a question about the SD card. I wanted to use the time lapse/model function on the computer. But it just says that my Bambu doesn’t support it. Do I have a defective SD card? I have already formatted the SD card using the Bambu menu.
Your SD card is an all or nothing component. If you were having compatibility issues the slicer would complain that a card was not found.
I don’t have an A1 but a simple test is this, do you see this choice when you send to your printer?
Upon printing you will see this icon glow with a red dot.
That means it’s recording.
If you take the SD card out after the print and put it in your computer, you will find the AVI file stored in a folder called timelapse
The filenames all begin with the name timelapse
Just copy it to your computer and view the AVI file with your favorite viewer. Note that there is an annoying bug in Bambu that creates a corrupted AVI file that has no index. Most AVI viewers will have the option to workaround this. I recommend VLC viewer if your viewer doesn’t work.
