SD card Slow & can't print
P1P printer. Now only prints via cloud.
No change to wifi that has been working. Original card began to slow taking 3-4 minutes to load a small print, changed to sandisk 64g v10 & tried 8g card which were formatted in machine, same problem. Print through the cloud works normally. No send error from sd.
Have reset computer, router, printer several times and all other devices work normally on this wifi. No hardware changes to this system
Camera and prints are normal.
Did you use the Eject option for the SD or did you just remove it while the printer was on ?
The later makes sure the SD will quickly be corrupted and might not be too nice for the printer as well.
Hate to tell you but the P series printer prints from the SD card if you send from Bambu Studio or transfer via the cloud. In both cases the gcode file is transfered to the SD card and the printer reads it from there.
Ejected with printer off.
Understand printing from the card, however I can’t send a file to the card and have to print via cloud, then eventually (3-4) minutes after printing had begun a file appears.
Thanks for replying
Try logging out of the account for both programs and the printer.
The assign it again.
Sometimes it is a hickup that got stuck somewhere.
