I move between my laptop and PC on a daily basis. I would like to be able to move between both so seamlessly that you almost wouldn’t know you have moved to the other PC. I already have a solution for some components as explained below.
- Presets
I use the built-in preset sync option under preferences as per screenshot below.
Project files
I use Onedrive to store my projects. The only time this isn’t seamless is if I leave Studio open on my PC or laptop without saving the project before moving over to the other machine. -
Studio software settings
To be specific, I am referring to everything under preferences as per below screenshot.
Could the solution to this be to share the AppData>Roaming>BambuStudio folder (see below screenshot) between my PC and laptop?
- Recently opened
Is it possible to synchronise this screen?
Example scenario:
I often finish working on a project on my laptop and come back to work on the same project but I open up Studio on my PC. The project doesn’t show up under recently opened and I need to browse for the project on my shared projects folder on Onedrive. See below screenshots of both.
I assume what shows up under recent projects is unique to each machine. Is the solution to this similar to my idea above under Studio settings? - share the AppData>Roaming>BambuStudio folder (see below screenshot) between my PC and laptop?
- Laptop
- PC
