I bought the R1, and it is big! I need to buy a workbench that is deeper, as my 24" tables in my garage won’t cut it. Has anyone found a sturdy workbench that fits the R1 that they would suggest? Is rock-solid sturdiness really important? I own a bunch of 3D printers, but this is my first laser cutter.
What’s available locally might be worth checking out and that varies.
In general, CO2 laser, a solid one to support the weight and inertia from toolhead fast movements, sturdy enough that you can move the table with the machine on top without the legs bending, but it doesn’t need to be absolutely ROCK solid. The toolhead moves much slower and doesn’t shake violently like FDM printers. Even sheet metal legs with some well placed bracings can be enough.
If in US you could try looking at Harbor Freight welding tables. I have one (for welding) that I put locking casters on and made the braces into a shelf. This is only 3 x 2 so may not be deep enough.
EDIT No it will not fall down, vibrate too much, or break. I have seen and used these benches with printed brackets. Do not listen to the traditional woodworkers trade union. You don’t need to half-lap, dovetail, and mortise and tenon everything.
Here’s what I built with some 2x4’s, 1/2" Plywood, and some 2-1/2" deck screws. Took about 2-3hrs to put it together, feels plenty sturdy. I’m probably under $50, but I already had the plywood and screws. I’ve already ran several laser jobs and stand hasn’t budged. I had to prop up one side of the laser on plywood to level since my shop floor is sloped to outside. Also used locking castor wheels for mobility in the shop. Made it 38" wide, 24" deep, 30" high. Going to make some organizers for my project panels, maybe try to squeeze in a pull-out drawer for the smaller stuff.
There is also the option that if your tables are moveable (or one you buy) you can make a bigger top for it out of .75 inch MDF or some other material.
I bought one of Home Depot’s Husky adjustable height workbenches. It is only 24" deep, but the feet on the R1 are only about 17.5" apart front to back. I also use one of these workbenches for my X1C. I have not been disapointed.
I bought the Masterforce® 45"W x 24"D Workbench at Menards at it works great. Super solid and no movement with the laser moving at high speed. Model Number: MFWB4524 Menards ®SKU: 2113350 $178
I use a Kreg build your own frame. I use a 45 x45 frame with a 19mm thick MDF top. Very stable and sturdy. Multiple height level adjustable and has a second shelf underneath for material storage. Ill upload a picture when im home.
I see you have the H2 Laser grid panel on your table. Does it also work in the R1? I’m new to lasers so I wasn’t sure it panels like that had to be coated a certain way for a CO2 laser, as compared to a diode one
I too have a small garage so I opted for a portable cart with lockable casters, pullout drawers and laptop tray. I have the R1 with riser and conveyor (and rotary I hope). Photos soon.
Here is the completed cart for my R1+Riser+Convyor in my over-crowded garage. Cart is from Harbor Freight plus all swivel casters with brakes, pull-out laptop tray and 2 pull-out drawers. Now to find a piece of aluminum honeycomb for the slide-out base (slats suck)… I also will share my tips and techniques accumulated for the past 20 yrs on how to produce surface finishing, smooth bevels, precision bending, welding and more for acrylic and similar materials. I look forward to getting experience with my R1! -mike
Looks good. I have my R1 but im waiting on my riser. Hows the seal between the riser and the r1 when not using the convayer. Is is sealed? Or just a brish seal?
The seal is as good as can be expected. But note it changes from class 1 to class 4 (laser) when you add the options so there are possible (laser) leaks. If you’re asking about exhaust, the blower maintains a negative pressure inside the combined system which is important. An external blower can’t hurt for a long exhaust hose.
