I’m printing a model wing using the BBL suggested settings for Aero and a single Wall Loop.
The weight is very good but I’m getting undesirable surface rippling. FWIW, I have done some sanding to the surface in the image.
You using prefoamed lite PLA? Because those settings need to be dialed in with a LOT of calibration first
Did you dry it? Noticing Bambu put a big warning on it
Sure did. Straight from the opened package into a dry box with desiccant. I suspect it’s a setting because all of the usual protocols are followed.
That’s good for storage, but it looks like they recommend 8 hours at 55C.
Ok thanks, woot.
Keeping an open mind and if some tweaking of settings doesn’t produce a result, thorough drying will follow.
D.
