Hi all,
So ive treated myself to an AMS not so much for multi colour prints but mainly so i can have black and white PLA and some PETG for support material and then i can have the PC in there also when i want to use it.
So i have set up custom filaments for the PLA white, PLA Black and PETG so under the device tab i can allocate the correct filaments to the slots in the AMS.
So my questions are…
- If i have the filaments selected as they are in the AMS, but i dont have multiple objects and not using object specific process parameters Orca will default to using filament no.1?
2.So if i want to print in the slot 2 material do i just select slot 2 when i go to print or will this just use slot 2 material but with slot 1 filament parameters as that is what its set to use in the process settings and so i either need to to change the no.1 filament to slot 2 or change it in the objects settings?
Hope that makes sense.
3.What settings do i need to use for flushing between 2 of the same material of different colour?
