It would be great to be able to select all of the items on a build plate to clear that plate. So far I have not found a way to select all of the items on one build plate. I have run into the 36 plate limitation-but that is easy to work around.
Also, would be great to be able to copy and paste objects across projects.
Right clicking the build plate gives you a menu with ‘select all’ and ‘delete all’ items.
And to add to the above, on Windows, CTRL-A and DEL.
