I use X1C a lot and love it but , changed the nozzle of the Prusa Mk3S+ to Revo 6 high flow and for similar quality the speeds are very close, sometimes is actually faster small prints due to start up time.
Yes still X1C is a bit faster due to the acceleration, but not the print speed and that if you do not count the 10min to 7min start up time , But for real good quality X1C needs to be slowed down quite a bit
On top of that i gave up on using TPU/TPE in X1C especially real soft ones too much hustle and usually not great result . So TPU/TPE only use Prusa
Theoretically X1C can print up to 500mm/S practically most materials i print should be bellow 200mm/S and some material bellow 100mm/S , esun ASA max speed 145mm/S without satisfactory layer adhesion , ABS 140mm/S without satisfactory layer adhesion - actual ABS/ASA speeds is around 100mm/S on the X1C for good adhesion
PETG depends what outcome - shiny not shiny but anything above 150-170mm/S is not a good print and for shiny needs to be well bellow 100mm/S
Prusa with Revo Six has a quick change of the nozzles so for 0.6 0.8 much preferred compare to swapping the X1C nozzles
So no will not retire the Prusa any time soon , find it for some prints in PLA and PETG slightly better and TPU well still cant get the X1C good enough quality and on top of that had to modify(drill) the X1C head so be able to control the tensioner as if you printed something like TPU 70
X1C is a great printer but to say that Prusa is miles behind disagree , and yes Mk3s+ can print with in 20%-30% of the speed for similar quality( note Revo Six high flow version ) and depending on the model , MK4 sure that is more or less almost identical for the same quality
EDIT:
I did increase a bit( almost double) the acceleration and no print speed of the Prusa as well compare to the defaults ![]()
EDIT 2: just had to run some parts in PLA and both Prusa mk3s and X1C a printing identical 36 parts nozzles 0.4mm and layer settings the same 16h15m on X1C , 19h05m Prusa mk3S+ Revo. Hope that clarifies , in PETG usually no difference or next to nothing
