Where is this label used? I thought it’s the name shown on the printer LCD but its not. Thanks.
Isn’t that where you name the file that you are sending?
Its the project name + plate number, but changing it doesn’t do anything that I can figure out.
I believe it just allow you to name the file rather than it being called ‘5bs_plate_1’ but I could be wrong. I’m still new to this myself
The name of what file, on the SD card? You would think but the when you go to print that SD file on the printer display, the printer doesn’t show that filename.
Sorry then I can’t help. Just got mine on Friday and still figuring out stuff myself
You’re gonna love it! Have fun.
bump, having the same issue. Anyone know a fix?
Verified answer - Thanks! Model name is the label on the printer display (SD card).
You can change this label as follows:
A .3mf file is nothing else than a zip file. Open it (you might have to rename it before), and you will find a directory named 3D. Open this folder and you see a file named 3Dmodel.model. This is a textfile. Extract it, open it with the standard editor. Search for wrong “Project name” and change it.
