Sending print job Cloud/LAN issues
Hello everybody. New Bambu owner here (but not new to 3D printing).
I see a LOT of posts about connectivity issues, so apologies if this has been answered already. I just got my new X1C fired up yesterday and I am experiencing the following issues:
  • Sending print jobs from Studio over the cloud is sometimes VERY slow, occasionally just hanging around 30% indefinitely, until I click “Cancel”.
  • I am able to send a single print job from Studio via LAN-Only mode, but any subsequent attempts to send print jobs fail and give me the “LAN Connection Failed” pop-up window, despite still having full control of the printer through the “Device” tab. The only fix to this seems to be to restart the printer and Studio, which will allow one more print job to be sent before I have to reboot everything again.
Both the printer and the computer are connected to the same 2.4 WiFi network. I have tried moving the printer closer to the router, but the symptoms persist. It doesn’t seem to be a signal strength issue. Thoughts?
Hello,
I have not had this problem but you might try a static ip on your router and check your 2.4 channels.
Are you still experiencing this issue? I just had this happen to me and everything on my network side is just fine. What’s odd is I can still send commands over the cloud (I just did a calibration test command from studio) but attempting to print my file just hangs are 30% and doesn’t move until I cancel.
Follow up…
Calibration seemed to clear things up.
Did you fix it? I have the same problem and i dont know how to fix it.
I power cycled the device relaunched studio and ran a calibration which fixed the issue.
Have the same issue with both my printers (P1S and X1C) and have to power cycle between each print. Very annoying :frowning:
For me, “Sending print job through cloud service” hangs at 30%. Have tried power cycling & calibration.
Back up now. There were many topics created saying the same thing.
mine still isnt back up. its hanging at 30% until it gives up with error code -3030
Currently experience the same issue as well. Has anyone come up with a solution?
I got my printer a month ago and this issue was happening to me also and I fixed it by updating the firmware and turning off LAN then I did one calibration after all that
Having lots of issues all of the sudden in LAN only mode. (5) X1C’s to the same computer, all are getting FTP issues when trying to print the plates. The problem is directly related to MS Defender, if I disable the Domain Firewall the prints shoot through super fast. I have added all the listed items on the Wiki page to the firewall but something has changed, this used to work just fine with no issue (probably on the MS side) I have 1000’s of hours on the printers and they have been working very well but our IT wants them in LAN Only mode so I need to find a solution to this. I can try a ‘Calibrate’ as listed above but in my head I can’t see why that would be causing an issue with FTP?
getting this same BS. Zero help on the discord, and nothing from labs tech support who will take a decade to reply at which point I will have solved this. Working on 1 printer but not the other. Of course there’s no solution because this isn’t here as a way to solve problems it’s just fan-mail for a bad service.
Will just keep trying to force it through.
Yup. My A1 mini says it uploads fine but then doesnt start the print. P1S sits at 31% then goes back to 30 lol. IM TRYING TO PRINT LIKE 25 HONEYCOMB PANELS
I have experienced this bothersome issue with failure to send files via the cloud to my X!C printer. Reinstalled Bambu Studio… no help. Restarted printer… no help.
A COLD REBOOT (shutdown and restart) has resolved the problem for the moment.
It is disappointing to see that Bambu hasn’t addressed this issue. I wasted 10 hours getting to the above solution. I have always maligned Microsoft’s standard solution…Reboot, Reinstall and Reformat. Today our friends at Bambu Lab need to clarify the issue and not just a reboot.
tenog el mismo problema, como le solucionaste
Yes the same here, a very slow or busy server I guess?
I have been having this problem as long as I can remember. After I open Bambu Studio, I can slice and send one print. Then all future sends fails despite being able to connect to and control the printer via the “Device” tab. If I completely shutdown Bambu Studio and re-open the app, I can send one more print before I have to do it all over again. Any advice?
Don’t know if this helps anyone but if I’m connected to a VPN, the send from printer won’t work. Disconnecting VPN allows it to work
